Nanoflex
Ahh fair enough then Paul
Well then it would seem obvious to test this against 4mm pieces of other material then.
I realise this isnt a spinner test, but its a fairly simple (and repeatable) test that can be done. If you want to test it with a spinner, you need to find a way to anchor the material down or you wont get a sensible result.
Only suggested this as propping a piece of material up against a wall and driving into it seemed fairly simple, and I can be certian that Storm II will hit it at the same angle, at the same speed each time.
Ed
http://www.teamstorm.comhttp://www.teamstorm.com
Ed
