AME D-Pack Motors
  • AME D-Pack Motors
    Does anyone know the particular output they have, and what advantages they have over Bosch 750s, LEM130s and S28-400s?
    Just curious.
    AME D-Pack Motors
    I think I need a bit more info. As any AME motor I find on the robotcombat website gives that the best they can do isnt even close to a Bosch 750.
      AME D-Pack Motors
      http://www.robotmarketplace.com/store_motors_ame.htmlhttp://www.robotmarketplace.com/store_motors_ame.html
      AME D-Pack motor (207-1002) NOT AVAILABLE
      Peak power: 4.78 hp
      No-load angular velocity: 6960 rpm
      Stall current: 1240 A
      Stall torque: 2770 ozf·in
      http://members.iglou.com/chadady/dpack.htmlhttp://members.iglou.com/chadady/dpack.html
      http://members.iglou.com/chadady/dpack.pdfhttp://members.iglou.com/chadady/dpack.pdf
      (Message edited by woody on June 27, 200
        AME D-Pack Motors
        Oeps, Thanks Woody.
        1240A stall..... Hawker Genesis and Albright relais.... nothing else will supply that inside a reasonable weight and pricetag.
          AME D-Pack Motors
          Using a 3S6P pack of A123s (10.2Volts) per motor, you would get around 1600 Watts out of them, so similar to a Bosch 750 at 36V.
          The problem is that the stall current would still be around 600 Amps, and getting a speed controller to handle that would be tricky.
          So probably easier to stick with Boschs at 36V (stall current around 170 Amps at 36V, including 10S2P A123s in the circuit)
            AME D-Pack Motors
            Advantages are (or were) cheap, robust, proven. Survives high power levels. Low diameter.
            Disadvantages. Low voltage (well below optimal for either solid state or contactors), high current wiring. Low torque constant, limited efficiency. Long. No cooling.
            Low efficiency means you may need to spend slightly more mass on batteries to get the same effect.
              AME D-Pack Motors
              Low efficiency means ...toasty motors.
