Advantages are (or were) cheap, robust, proven. Survives high power levels. Low diameter.
Disadvantages. Low voltage (well below optimal for either solid state or contactors), high current wiring. Low torque constant, limited efficiency. Long. No cooling.
Low efficiency means you may need to spend slightly more mass on batteries to get the same effect.
