Vulcanon/vulcanore
    Vulcanon/vulcanore
    dunlop kt3 is a good wet tire to try, weve been using them for a while.
    The problems we have tend to be about power not grip.
    Mark.
    Taurus
      Vulcanon/vulcanore
      has anyone else had experiance with the kt3 ?
      weve been using the sl1 rear tyre and its like the robots on ice
      cheers jim
        Vulcanon/vulcanore
        does any one know how thick the ali wheels should be coated,idealy for this soft polyurethane (rubber)
          Vulcanon/vulcanore
          Report on Vulcanon wheels. For Preston event we fitted new wheels to give them a test and after the last melee we dont have any Vulcanon left on the underside. We had about 8mm of tyre on 3 inch dia wheels. After a quick hard 5 minutes test at home all we got is a few scuffs and decided to try them at preston. We got 2 fights in total including the melee. After the first fight it didnt look like they had worn much at all but after the melee and a mess around with Air & cutlet at the end we were down to the metal. Dont know what happened but maybe they didnt stick to the wheels as good as they should.
          Jonno, did you see any large lumps of Vulcanon when clearing the arena. Would like to know if they came off in one lump or not.
            Vulcanon/vulcanore
            Mark, How do you define the underside of a wheel?
            -- Kev
              Vulcanon/vulcanore
              No he means underside on the robot not the wheel.
                Vulcanon/vulcanore
                Erm... Oh does it have wheels top and bottom? As in the underside set of wheels? If not then Im still confused.
                -- Kev
                • #23
                  Vulcanon/vulcanore
                  Perhaps he means the tread as opposed to the side-walls of the wheels.
                  • #24
                    Vulcanon/vulcanore
                    No, We have 4 wheels on top and 4 on bottom (all drive wheels). Take a look at my profile. Still dont know if it was battle damage that ripped them off or they wore down. Either way I dont think therere suitable for such small wheels. Pitty they gave alot of grip but just too expensive to replace them after every event.
                    • #25
                      Vulcanon/vulcanore
                      Mark, you havent thought about creating a website for Big Nipper?
                      • #26
                        Vulcanon/vulcanore
                        I dont know if any one else had noticed these,
                        shame there on cast iron wheels !
                        http://rswww.com/cgi-bin/bv/browse/Module.jsp?BV_SessionID=http://rswww.com/cgi-bin/bv/browse/M...gkldfhn.0&cach eID=uknetscape&3276535608=3276535608&catoid=-669969991
                        GORD
                        • #27
                          Vulcanon/vulcanore
                          Just for info, the correct spelling is Vulkolan.
                          • #28
                            Vulcanon/vulcanore
                            Guys what general depth do people get vulkolan put on to? I know KR2 used 5mm but is that alot, or very little.
                            Please let me know.
                            Regards
                            Ian
                            • #29
                              Vulcanon/vulcanore
                              well i think ive got the most with 1 inch did try 2 inches but that was flexing gave a too soft reaction when adding lots of traction
