OOTA
  • #46
    OOTA
    Does chucking out Ceberus in the series 6 qualifiers count !!!
    Bulldog
    • #47
      OOTA
      Ill see if I can do the first middleweight OOTA. Im using Tonys old radio gear again and Im collecting bits for a low pressure flipper. Its going to be close on weight especially with a 2 kg fire extinguisher. Still if I can only get under that horrid spinny thing...
      • #48
        OOTA
        Of course Tony. Of course
        Mike
        • #49
          OOTA
          Julian, for a middleweight, it seems that a 1.1 kg bottle or even 2 600 gram paintball bottles are a better option for weight and space.
          (the 2 600 gram bottles have the added advantage of more heat exchange surface and easier placement-so that would be my solution)
          • #50
            OOTA
            blazer is running a 1.1kg bottle, i get about 52flips with a 80mm bore 210mm stroke ram at 10 bar.
            • #51
              OOTA
              How are things regarding Robot Wars rules? The Killerhurtz site says CO2 fire extinguisher. This is the only type of gas storage tank now allowed in Robot Wars UK.
              Yes it is flipping (pun intended) big. I was made redundant and they took at the high tech stuff away from the house and left the fire extinguisher. It will just fit widthwise in the stainless steel box I plan to use as a body. However it seems that most middleweight battles will be melees so the amount of gas may be an issue.
              Ive got bids on ebay for some of the other stuff that I need.
              • #52
                OOTA
                Alan, the difference in empty weight between the two bottles is 2 kg and money is something of an issue. Given the choice, I would use the smaller bottle.
                • #53
                  OOTA
                  I think counting should start again once youve been oota-ed yourself.
                  sorry mike.
                  • #54
                    OOTA
                    WJ, thats not funny! Mind you what was funny was seeing Mr Psychos hammer bouncing on your flipper.
                    Mike.
                    • #55
                      OOTA
                      My robot not being able to drive anymore cause the antenna wire came off wasnt funny... Behemoth doing its best to push me into psycho on the other hand, was very funny ! But a rematch in an arena without edges to throw over should make a good fight, right Mike ?
                      • #56
                        OOTA
                        Oh dear yes sir. Most certainly.
                        Mike.
                        • #57
                          OOTA
                          Well, lets try to make it so !
                          I will be attending the GRA event and the Newark event the week after that... CU there ?
