Hastelloy
  • Hastelloy
    anyone know where you get some in sheet form??
    i have been using it today at work, we can only get it in bar form.
    its wickly hard and strong
    Hastelloy
    Hastaloy is a nickel super alloy; And I never have seen it except in rod or cast complex shapes.
      Hastelloy
      nickel based alloys are valued for their creep resistance really...to use it on a robot is a bit ott by anyones standards, as more suitable materials are available for less.
        Hastelloy
        I have worked Hastalloy in pumps for the chemical and petrochemical industry. Mainly in very corrosive and hot liquids.
        Thermal resistance is one of the properties. Others include high mechanical strength and chemical resistance
          Hastelloy
          I too have worked with Hastalloy for a valve
          company in the oil, gas and petrochemical industry.
          It was used for extreme sevice valves,it was
          expensive and a right pig to machine.
            Hastelloy
            it was expensive and a right pig to machine
            sounds perfect for building bots
