Hi all, I’m back again seeking some advice haha. Hope you don’t mind.
So I was doing a bit more last night and decided to setup the Failsafes. After no joy trying YouTube vids, searching this forum and following the instructions that came with my transmitter I found this...
“The AR6210 features SmartSafe failsafe. SmartSafe is ideal for most types of aircraft. With SmartSafe, when signal is lost the throttle channel only is driven to its preset failsafe position (normally low throttle) while all other channels hold last commandâ€
That’s a bit of a problem because I need all channels to fail at Off which this obviously doesn’t do.
So my options, I think, are to change the receiver to one that someone recommends that supports the full failsafe mode.
or run my entire bot through a contactor or 2 that is held closed by the throttle channel. I don’t really want to do that though as it is more weight and failure points.
So if anyone has any advice or options here it will be appreciated. :-)
