@RougeTwoRobots thanks a bunch, saved me in the nick of time!!
Speed Controllers - Making Sense Of It All
I'm going to run a couple of these in my upcoming build.
https://hobbyking.com/en_us/hobbykin...d-car-esc.html
Any thoughts? If not, any suggestions? (brushed please)
The description says 'Forward/Brake/Reverse' which may mean there is a significant pause between forward and reverse. There isn't enough info to be sure, so I would order one to test. The 7.4V limit is rather low; the average drill motor will be well down on power at that voltage.
I have one of here currently sat on my test setup, single motor test running an Argos drill motor, seems ok, but not done any extensive testing.
Not sure they can handle the stall current or be able to dissipate the heat quick enough, but like I say, I haven't tested it properly and it's only 2s!
Just posting a demo, a ROUGHH video showing it running my Argos drill motor from a 11.4v nicad,
https://youtu.be/rCl4gA-V298
Poor video made in a rush, some reason there is no sound and uploaded to my other YouTube account... but shows it running with servo tester manually speed then automatically running through max to minLast edited by Roboteernat; 16 March 2017, 00:06.
Currently im running 3s on my design, speed so far is topend shy of 3 meters per second. I think thats good enough for my feather, add in some friction and weight, im happy with that speed. I do have some larger wheels on order too but my design means i need lower wheels.
those motors are able to go top speed 700rpm no load.
I would advise against the use of the hobbyking esc.
Does anyone know of a good, cheap, brushed ESC on hobbying that can run up to 12 NIMH cells and a 12ish volt discharge for a featherweight (I'm using them on a pair of Bosch 35ws)? Sorry it's so specific. I just need a decent ESC with a decent discharge voltage and can handle a decent amount of cells. Any suggestions?Last edited by Theo; 16 March 2017, 23:23.
Hi I took the advice which was very much appreciated and bought one from Rory mangles, I also bought the cheap one from eBay to setup with as I'm new to this and didn't want to blow a £55 esc. The eBay one only has one 3 pin cable to connect to the Rx and when I connect to ch3 of rx I get both motors turning fine when I push left thumbstick forwards however it doesn't respond to left and right inputs. If I connect to channel 4 the motors spin when I move thumbstick left and right. The Rory mangles esc has two 3 pin connectors so I guess my question is how does the eBay one tank steer with only one 3 pin cable?
Originally posted by AIDAN View PostHi I took the advice which was very much appreciated and bought one from Rory mangles, I also bought the cheap one from eBay to setup with as I'm new to this and didn't want to blow a £55 esc. The eBay one only has one 3 pin cable to connect to the Rx and when I connect to ch3 of rx I get both motors turning fine when I push left thumbstick forwards however it doesn't respond to left and right inputs. If I connect to channel 4 the motors spin when I move thumbstick left and right. The Rory mangles esc has two 3 pin connectors so I guess my question is how does the eBay one tank steer with only one 3 pin cable?
