Pre-Build Check
  • #31
    Pre-Build Check
    Ewan roughly what were the dimensions you used for mm 04 v2 because I have someone who is going to laser cut my steel/ali and i need to supply him with measurements.
    • #32
      Pre-Build Check
      Its 420mm wide - so 400mm inner width
      • #33
        Pre-Build Check
        One last thing, how long is it and how wide are 100mm blue tyres
        • #34
          Pre-Build Check
          Firstly, how long it is, Im not going to tell you that. You cant copy every last detail of your robot, Im sure youll find a size which fits you best. Also, email James Cooper regarding the wheels, youll find the address on http://www.robochallenge.co.ukwww.robochallenge.co.uk somewhere.
