Wheel placement
  • Wheel placement
    When going with 4wd off belts, my wheels are the same resistance etc but I want to encourage the robot to pivot more round the front
    I have the option to have the back wheels out slightly wider than the front but still run the belts straight, will this encourage what I am after or just make it a pain to turn?
    I think you're best off getting the weight biased to the front or reducing the grip of the back wheels in relation to the front (or both). Not sure how more spaced back wheels would affect the drive, probably not very positively. :P
      I have no idea if it would drive fine or be awful but its an option I have to consider
      Forwards and back shouldn't be a problem I would think as it all points the same way but it's turning I question
      Forgot to note though the front wheels are the driven ones with belts to the back
        just have less grippy back wheels
          Its them blue banebot ones with the bearings I got off you and some more worn robochallenge ones
            I get the feeling wider back wheels would make it worse, a wider wheelbase turns more easily (less skidding), so those would grip more, taking the front wheels with them. It would drive fwd/back fine though. Again more weight over the front alone will do it, as it happens T2 and Rango both drive around the front wheels as there is more weight on them. If you can't shuffle weight around though, for the sacrifice of a bit of overall grip, the easiest way is to make the back wheels grip less than the fronts.
            edit: wait, two different wheel types? Robochallenge wheels will grip way less than the banebots.
              They have the same kind of feel to them but one set is new and the other isn't, pretty sure they are banebot blues but got them of calum so he would know
              Weight I can shuffle forward easy enough with my weapon also being places forward, sacrificing badass-ness for reduced weight and drive reliability haha
                no they were off the coopers they arent banebot wheels
                  You could screw bike tyre round the front wheels and leave the back wheels 'bare' to get more grip at the front than the back.
                    My 4wd feather weight turns more from the front rather than the back
                    https://www.youtube.com/watch?v=HKgVbVjdVR8
                    As allready mentioned this is from majority of the weight being at the front (motors and large steel front) and the back only holding light electronics.
                      Are those leds on the back plate. Looks awesome marco
                        Thanks man. Its a bluetooth controlled RGB LED matrix. It lets me change different graphics on the fly. I can say PTO when I am upside down or when a house robot enters the arena I choose a crying smiley.
                        Here is a video of Trojan in action
                        https://www.youtube.com/watch?v=xNs9OdP27-w
                          The robot will want to turn about its centre of mass. Ignoring spinners which mess with this, you want to get your weight as far forwards as you can. That is the simplest option.
                          The issues with messing with the wheels are that A) the banebots wheels are 73mm and the robochallange wheels are 75mm which will mean that one set is trying to drive faster than the other. This can be solved by lathing down the robochallange wheels to match and b) the banbots wheels will wear down faster meaning in order to keep the wheels the same size you will have to keep turning down your rears. A few mm may not seem like much but in time it will kill your motors.
                          To give you an idea, in 4 matches Conker 3 went from having 5mm of ground clearance to having just 2mm and Binky went from 6 to 3. Both run Blue 73mm banebots.
                          Just some additional info for you :-)
                            Could you not use omniwheels like HypnoDisc and Razer used to (I think, anyway) because that'd keep your centre of turning around the front. I'm fairly sure they're a lot more expensive, and more brittle than your typical wheel but I guess it's an option if you can't shift your weight any more further forward...
                              I swear I saw Binky had the orange wheels at Yeovil?
