Pneumatic
Chad, in the UK and the Netherlands several of the 12 kg (26.5lbs) featherweights use full pressure CO2 pneumatics. They are in the end not that much more expensive than low pressure and they give a lot more OEMPH for the weight used for them.
On the other side, I do have a reasonable supply of Low and High pressure rams ,valves and buffertanks. Everything between 100 and 1000 psi. Mail me for more information.
