Pneumatic
  • Pneumatic
    I have built a robot on Rexs Robot Challenge and am looking to update the machine to pneumatics. I am on a budget and need to know what i need to start as i have no experience in this area
    Can anyone help?
    Pneumatic
    Heres a great place to start:
    http://www.technobots.co.uk/Technical/Guidance/A%20Guide%20to%20the%20Design%20and%20Use%20of%20L ow%20Pressure%20Pneumatics%20On%20Fighting%20Robot s.htmhttp://www.technobots.co.uk/Technica...e%20Design%20a nd%20Use%20of%20Low%20Pressure%20Pneumatics%20On%2 0Fighting%20Robots.htm
    It covers heavyweight pneumatics but featherweight pneumatics are exactly the same really
    Youll be looking at quite a large price tag for a conversion to pneumatics Im afraid though
      Pneumatic
      How can i get hold of Co2 ? If i use air what sort of cylinder is best ? and where can i purchase one ?
        Pneumatic
        Co2 is available at 99.9% of Robot Events so you can just refill your bottles. Use the link I gave you so that you can calculate how big a stroke and bore ram you want. Technobots sell some cheap low pressure rams, but check the for sale section in the forum where a few can be found.
          Pneumatic
          If it is still for Rex Robots challange then I would surgest a bicycle pump with a compresser set up. They are quite cheep. Will give more info later when I find it on my other computer.
          Regards
          Ian
            Pneumatic
            Tom - John Reid from Terrorhurtz has a good pneumatics how to on his website. Again its aimed at heavyweights but could be of some use.
            http://www.johnhmreid.dsl.pipex.com/killerhurtz/howto/pneumatics.htmhttp://www.johnhmreid.dsl.pipex.com/...pneumatics.htm
            Ed
              Pneumatic
              http://www.teamdavinci.com/understanding_pneumatics.htmhttp://www.teamdavinci.com/understanding_pneumatics.htm
                Pneumatic
                If it is for Rexs challenge- I wouldnt suggest bike pumps...because there crap, You can pick up cheap rams of ebay, Or im sure if you place a wanted add on the forum you will be able to pick one up- Also I looked into it exstensivly and my old feather Turbine 3 would of been classed as illegal for using a compressor.
                If its not for RRC you can buy bottles from Jackson+keay, a valve, fittings and pipe from technobots and you could probably pick up a small regulator of someone on the forum- or get a welding reg moded.
                Jackson & Keay Ltd
                Private Road Number 7
                Colwick Industrial Estate,
                Nottingham,
                NG4 2JW
                01159617113
                Hope this helps.
                  Pneumatic
                  Does anyone who how to control a solenoid 5 port valve by radio control ?
                    Pneumatic
                    The normal way is to use a RC switch:
                    http://www.technobots.co.uk/en-gb/dept_78.htmlhttp://www.technobots.co.uk/en-gb/dept_78.html
                    or you can just have a servo hitting a microswitch.
                      Pneumatic
                      I am looking for a M5 solenoid 5 or 4 port valve but am struggling to find one. Anyone know where i can get one ?
                      Tom
                        Pneumatic
                        1/8 bsp is more common. M5 is realy small.
                          Pneumatic
                          I have started a featherweight flipper project with a friend of mine. I have the whole system picked out but the valve and cylinder. I know I will use something in the 38mm x 160mm range for the cylinder. But as far as the valve I have not had much luck finding many good ones. I need a double acting valve with the best possible flow and PSI ratings. Anybody have something that they would recommend? Thanks!
                          ~Chad
                            Pneumatic
                            Hi Chad ,
                            What is your gas ... CO2 or Air?
                            How much will your regulator flow ........if its flow rating is low youll need a buffer tank.
                            Port size of your 38mm x 160mm ( 1.5 x 6 ) ram ?
                            Can you add extra ports or increase their size yourself?
                            Woody
                              Pneumatic
                              Hey Woody, thanks for the post! You have helped alot of US builders, I was kinda hoping that you would reply.
                              This system is going to use Co2 for power.
                              I have been looking at this regulator to use. http://www.palmer-pursuit.com/online-catalog/stabilizer-female.htmhttp://www.palmer-pursuit.com/online...zer-female.htm
                              Some people around here have used it and I have not herd any bad things. Any super secret UK regs that you think might be better? I was kind of planning of a buffer tank regardless to try to keep freezing from going on.
                              I have not actually picked out the cylinder yet, but I would like to get one with at least .25 (6.3mm) ports if possible.
                              My choice of Valve and will determine what cylinder I pick.
                              -I could go with a Spring return such as http://www.Mcmaster.comwww.Mcmaster.com part # 6498K548 @ 150PSI if I were to find a large valve that could really give some awesome flow.
                              - Or a regular aluminum double acting cylinder @ 140PSI
                              - Or a steel double acting @ 150PSI
                              Here is where I need some advice. What cylinder/regulator/valve combo would give me the best toss? I would like to have something like a 30pound Toro, little sister or any other nice flipper bot that you can think of.
                              ~Chad
