Pneumatic
Mister Woody/Mario and anybody else who knows about pneu stuff. Now that Rocket (60lb Light weight) is getting built I am looking forward to the next bot. I REALLY want to get a feather weight FP flipper going. Something that can flip another feather a minimum of 6 feet in the air and be really compact; the hardest thing that I have had to deal with is the size issue! I can get all the parts and everything into an acceptable weight range, but then when I go to build a robot around it, the bot ends up being MASSIVE due to the size of the tank, buffer and valve and fittings. I think I can probably get Mister Mario to build me a system which has a manifold/buffer tank which will allow for some space and weight savings. And then I can mount the tank and use a flex hose to save space, but then there is the valve problem. The Burket (or whatever the standard valves name is) is big and heavy! Anybody know of another valve that is able to take FP but yet is smaller than the burket?
Thanks for the help guys. I will post pictures as parts get made for Rocket.
