Chris,
0.2mm on diameter is perfect. When drilling pre-drill to within a couple of mm of finished size. If the reaming drill has to do too much work it may cut oversize and ruin everything.
Get the ream holes dead size for the bearings and loctite 603 or similar will hold them in the plates without needing retaining plates.
The gears should Loctite well but if not make a small collar and loctite that to both the gear and axle as well.
Trev
Trev
the gears are made of some type of steel for sure as its magnetic and flies yellow sparks when ground, like these:
