Well my reason for switching to brushless was a bit more unusual. I took Huntsman to RoboGames 2012 and during it's second fight agaist Last Rites it had all 4 motors fail due to popped out brushes and shattered magnets. Then at our Nationals in 2012 my Vendetta failed in the finals for simalar reasons. So I chucked a wobbly at the world of complex brushed motors and went brought the brushless setup. I wanted cheaper motors that are made with less parts and smaller magnets, and therefore less likely to have mechanical failures from shock.
I chose the because NTM 42-30 750kv because on 4-cell they should hit 10800rpm. With a 10:1 reduction and 100mm wheels that is a calculated 5.65m/s. Under load it's probably half that and would therefore take 1.7 seconds to drive across our 4.8m wide arena which was simalar to my previous robot. I do all my calculations in m/s because we only drive a few meters before hiting the other side of the arena, in a few seconds, so miles or kilometers per hour isn't relatable. So 10mph sounds slow, but 2 seconds across an arena sounds decent, and it's actually the same thing.
