IBC help
  • #46
    IBC help
    Yeah very true. So as Geoff said, maybe the wording of the rules or somethnig needs to be looked at then.
    Mr Stu
    • #47
      IBC help
      The LED Thread is too big so Ill post here . On Blue we had a blue power light on a blue painted robot and no one complained. Although we did change it to red every now and then due to wiring up the wrong LED.
      On the new version it is Surface Mounted in the only bit of Aluminium chassis, there is 4.5mm of white polypro (not transparent) above it. When the light is on you can see it clearly as about 3cm sq of the polypro turns red. Much more visible than just a single 5mm LED would be.
      I also dont remember anyone complaining about Mighty Mouse and the other one I cant spell where there is a massive white halogen (I think) light inside his robots that light up through all the gaps in the armour, also very visible.
      At the end of the day its the tech checker and event organiser who will say if its expectable or not, For minor rule discrepancies Ive seen tech checkers say they will allow it to run this time but they must alter it for next time, so even if you do turn up with a new robot with a power light not surface mounted then the worst that should happen is you are told to change it for next time.
      For a picture of the new Blue, now renamed Litter Hitter because its not painted blue, see my profile. It€™s now CO2 instead of a compressor and has a bigger ram with twice the size buffer tanks and an axe head twice the weight of the original. On the picture the LED is located next to the lower left bolt on the top surface but is not visible as it€™s on the kitchen floor and has the link removed.
      • #48
        IBC help
        I love it Mark!!! Nice One!! And you have an IBC in that as well so it fits in the thread
        Mr Stu
        • #49
          IBC help
          Wow, neat robot. How far does it jump when you fire the hammer?
          • #50
            IBC help
            Resistance is futule, all threads will be assimilated by the LED conversation
            • #51
              IBC help
              *shivers*
              • #52
                IBC help
                Contacts Species 8472!
                Mr Stu
                Ps - Only treckies will know what im on about, and im not retarded, just special
                • #53
                  IBC help
                  mmmmmmm
                  • #54
                    IBC help
                    http://www.geocities.com/Hollywood/8459/species8472.htmlhttp://www.geocities.com/Hollywood/8...ecies8472.html he is one ugly bugger
                    • #55
                      IBC help
                      You will all become one with the LED conversation.
                      • #56
                        IBC help
                        And only last night you was saying that i was sad because of my interests Stu hehehe... each to there own.
                        Chris - http://www.featherweights.org/forum
                        • #57
                          IBC help
                          Fair Play Chris, Fair Play
                          Mr Stu
                          • #58
                            IBC help
                            Enough the Borg quotations,huh? Fair enough.
                            Could our own little collective conciousness, (Well, we never seem to be unconcious anyway...), take a look at this http://uk.geocities.com/team_psychostorm/Technical.html
                            • #59
                              IBC help
                              Try 470 for R1 and 100K for R2
                              • #60
                                IBC help
                                Yep I was right. In the middle of the night it hit me. Ive left a 100 Mega ohmn resistor in there. I needed sleep to say the least.
                                Thanks Stefan, Ill try your sugestion when I get home from college.
