Hi,
I've upgraded my fw flipper from 3s to 6s, the problem is that I forgot about the led strips which are only rated for 12v. To stop them blowing up I wondered if I could put a resistor in parallel with the hole strip, if so how do I calculate the size of resistor?
As a side note- I tried plugging in the removable link (forgetting about the LEDs) and there was a lot of sparks and smoke from the deans connector melting the contacts- could this be because of the LEDs?
Thanks,
Max
Thanks,
Max
 across the battery terminals there is a resistance if 0.5 ohms when not turned on and with the motors unplugged. I think that would make an instant current of nearly 50A so that could cause all that sparking. Any one know what kind of resistance there should be across the terminals? I imagine it should be very high as the only route for the electricity should by the LEDs which should have a high resistance.
