Hi,
I've upgraded my fw flipper from 3s to 6s, the problem is that I forgot about the led strips which are only rated for 12v. To stop them blowing up I wondered if I could put a resistor in parallel with the hole strip, if so how do I calculate the size of resistor?
As a side note- I tried plugging in the removable link (forgetting about the LEDs) and there was a lot of sparks and smoke from the deans connector melting the contacts- could this be because of the LEDs?
Thanks,
Max
Thanks,
Max
