Axe mechanism
I would reccommend having a belt or chain in there, we found on the Rad fan motor axe mentioned by James Cooper that the shaft was a simple push-fit, so with the impacts directly onto the gear welded to the motor, it seperated the shaft from the armature. Some shock protection is needed. Also, dont weld the case of the motor, it melts the glue on the magnets and allows the magnets to move inside the motor case. I wanted a fusee drive in this robot but was out-voted, so Id recommend it here.
Lastly, watch your gear reduction, we used approx 6.6:1 but this was way to low and was basically a cost driven solution. Invest the extra few quid and do it properly. If using the mondeo deisel fan motor aim and asuming a shaft length of 330mm and an arm weight of 1.5kg, I would suggest 9:1 or even 12:1, if for no other reson than it makes self righting less of a battery smoker.
Also, the fan motor worked quite well at 12v, but was insane at 24v (until the motor was damaged by welding) so if you get the gear ratio right there should be no need to have silly voltages, and of course as the voltage goes up, the gear reduction can go up to, so 9:1 at 12v can easily be canged to.... say... 12:1 or 14:1 at 24v. all of which helps self righting.
Hope this helps.
Hope this helps.
