I am considering to build and axe robot i was wondering what mechanism to choose . I know there is pneumatic ones but could that be in corparated in a featherweight?
Axe mechanism
Axe mechanism
There is a co2 axe being made by Wayne cummings. called Basher. its got a revolutionary design like no other axe. its also 16 bar which will make it the most powerfull axe around. Rc Wars have produced an electric axe and boy is it good. its debue will be at the Rc Wars Championships
Axe mechanism
To the left on your keyboard, theres a button called Caps Lock. Press it, and you can type without annoying people. Capital letters are most commonly used when screaming, something that you generally stay away from on a public forum.
But as Ian says, there are tonnes of diffrent windscreen wiper motors. Some might work, but theyre most likely too slow. Some cordless drills would work better.
Axe mechanism
Even the cheap 24v drills you can get from maplin or argos (and other places) have lots and lots or torque- arguably motor than WW motors.
As someone with no expirience with WW motors :sad: Can I ask what the output shaft usually consists of? Is it a simple keyed axle?
And yes, capitals are annoying, I also find it annoying when people use capitals on ebay or the for sale section of this forum, believe me- IT DOES NOT WORK
Axe mechanism
Note that the weight of the axe head is not particularly important (for power) in a pneumatic axe, as long as you have good ram speed. A lighter axe head also tends to make the robot jump less.
However, on an electric axe, the only way of getting a good level of enery into the axe is by having a very heavy head on the end of a long shaft. The motor is producing energy at a constant rate, so the longer the swing time, the more energy will be in the axe head at the end.
