Burket control
  • Burket control
    What do people use to control their Burket valves?
    Need to figure out something different for bulldog as it's not dumping the gas yet I figures it can just be scaled up
    Re: Burket control
    http://www.hobbyking.com/hobbyking/stor ... itch_.html
    Cheap, light, failsafes and hasn't let me down yet.
      Re: Burket control
      [quote=mr_turbulence]http://www.hobbyking.com/hobbyking/s... <br /> Cheap,
        Re: Burket control
        We've been using Battleswitches in Mute, only done a few events but they seem fine
        http://www.dimensionengineering.com/...s/battleswitch
        Got them direct from states because we needed a couple but think you can get them from the UK, was a really good service from the states
          Re: Burket control
          Andy, my turnigy switch doesnt latch on as you describe, single action on or off.
          Had nothing but problems with dimention engineering products... bec's esc's and i know many had troubles with there switches being intermitent and un-reliable.
            Re: Burket control
            Use them in Skyfall, never failed me. Been in use since Barnsley this year, still going strong as ever.
              Re: Burket control
              Only problems we found were when firing the flippers, sorted with a diode on the solenoid valve and haven't had any problems since, but like i said only fired it over the few battles we've had.
              We used to use the team delta boards http://www.teamdelta.com/products/prod2.htm (think they were these, Daniel does all the elctronic stuff) worked a treat though
                Re: Burket control
                used battleswitch, would never use again.
                  Re: Burket control
                  don't like Battleswitch's far too sensitive and regularly mis-fire when you get a hard knock. The electronize ones were great but you cant get them at the moment. Team Delta ones from the states have always been good. A few people are using the Technobots ones without issue.
                    Re: Burket control
                    i use bot switches seem fine dont know if they caused some misfiring on arming up for the previous event , it didn't happen at deeside. dont get me started on burkerts though
                    I had 3 spare kits for the champs just incase but didn't need any, maybe they are building them better.
                    matt are you going from lp to hp with 2 2kg buffers straight away big increase you want some power then !
                      Re: Burket control
                      I'm going from FP no buffers to FP with buffers, power is what I'm after but a better way of controlling the valves aswell, the current system works but takes far to long to exaust so want something thats just on/of as it was before
