Buffer tanks...
  • Buffer tanks...
    Hi,
    We are currently in need in a lighter buffer tank, at the moment we are using a 20oz co2 bottle with a modified pin valve (thanks Will for telling us how to do it) and I was wondering what else we could use.
    I saw that the big nipper team were using modified camping bottle that they got pressurised, so that may be an option, but personally I would like a bigger Buffer tank. So I was thinking of a foam fire extinguisher.
    Does anyone know what the imput thread is on the bottle?
    Re: Buffer tanks...
    1. go down to your local scrap yard
    2. pick up a large quantity of old foam fire extinguishers for about a quid each, avoid rusty ones
    3. atleast one of them should have a thread close enough to a standard bsp thread for it to work, jam a fitting in and araldite in place
    tips: bring a 1/2 bsp fitting with you and compare the od of where the valve enters the cylinder to the 1/2. this will give you a good idea if the extinguisher will be suitable. also avoid the really cheap disposable ones (easy to spot, they have plastic valves) as there is no screw part in them.
      Re: Buffer tanks...
      that may work
      do you know what the dimensions are for them?
        Re: Buffer tanks...
        they vary tremendously
          Re: Buffer tanks...
          ohh right I've only got 11om of height to play with...
            Re: Buffer tanks...
            shouldn't be hard to find one the right size though
              Re: Buffer tanks...
              Do you mean it must be 11cm diameter
                Re: Buffer tanks...
                well the height of my robot is 110mm and i have to fit a solenoid valve and a esc underneath it
                  Re: Buffer tanks...
                  How long do you want it?
                    Re: Buffer tanks...
                    Worst case scenario. I could create one perfect fitting from Ti tube and end plates.
                      Re: Buffer tanks...
                      That may be a tad too expensive
                      about 250mm but around 0.5l volume
                        Re: Buffer tanks...
                        I've got one here, about 0.85l volume, 230mm long in total (19cm without fitting) 70mm diameter. Working pressure 14bar with a 1/2 thread
                        Pm me if interested
                          Re: Buffer tanks...
                          You never know, a search on Ebay could yield you the right basic stuff.
                          Welding it up ain't that hard.
                            Re: Buffer tanks...
                            Ill have a look at the scrapyard and see what they have, if not Maddox your option would be ideal
