motors
  • motors
    which motors are better :
    http://www.ebay.co.uk/itm/190660369831? ... 1438.l2649
    or http://www.ebay.co.uk/itm/160777373998? ... 1438.l2649
    also are any of these batteries good?
    http://www.ebay.co.uk/sch/i.html?_nkw=3 ... m270.l1313
    sorry i have so many stupid questions.
    Re: motors
    2nd link doesn't work.
      Re: motors
      fixed it
        Re: motors
        I think the scooter motor will be more powerful but that's just a hunch. Both motors would need gearboxes though, with the scooter motor it would be fairly easy to have a reduction using chain and sprockets but for the Mikita motor you would probably need the matching gearbox. If I was you I would go for the Gimson motors or Argos value £12.50 cordless Drill motors for your first bot, they are very simple to use and ou don't need to worry about gearboxes.
        For my first bot I tried to use windscreen wiper motors despite everyone advising otherwise and still haven't managed to finish it due to complications and difficulties only caused by the motors. But I have managed to make 3 robots using drill motors and robochallenge wheels, it's just so simple!
          Re: motors
          The Makita motor is the more powerfull, smaller, lighter but with a much higher RPM.
          The scooter motor is large and heavy, but with the lower RPM easier to work .
          Concerning batteries. you can't do much wrong with the vapextech one. But you'll need 2 of'm for the scooter motor, the Makita can work on the 8.4V of the first Vapextech pack.
            Re: motors
            any links for good drill motors?
              Re: motors
              are u after 12v or higher
                Re: motors
                http://www.argos.co.uk/static/Product/p ... 418778.htm
                  Re: motors
                  ive used argos ones in my 4x4 robot and they are defiantly cheap and cheerful but for my second robot i found these http://www.ebay.co.uk/itm/BRAND-NEW-GEN ... 35b8213ae2
                  they work out about the same but you don't get any battery but most people don't use the drill packs and they are better build quality and a bit faster
                  the seller also has some more expensive and more powerful bare units
                    Re: motors
                    thats really helpful but will they power my robot
                      Re: motors
                      Do you mean are they powerful enough? If so then a lot of robots use those drill motors and they are quite fast and powerful, you won't be the most powerful pusher but for your first robot there great! If you want more power then you can go for gimsons which will be more powerful.
                        Re: motors
                        i think i will get gimsons if they r in my price range but my robot is a thwackbot and needs alot of power
                          Re: motors
                          Plain grimsons are £24.50 but you can choose conectors and wires for them as well for an extra £1.70
                          grimson website: http://www.gimsonrobotics.co.uk/GR01...gearmotor.html
                            Re: motors
                            the scootoer motors are more powerful and will probably give me more impact when i attack enemies but i dont know what would be suitable for this esc:
                            http://www.technobotsonline.com/saberto ... or-rc.html
                            the only reason i suggested the scooter motor is because they are cheap and i thought they were good but if push comes to shove i will buy the gimson motors.
                            A quick question, which of your robots were most successful? what kind of robot are they? did you have any tactics?
                              Re: motors
                              scooter motors will end up costing more than the gimsons once you buy gears.
                              also, i don't like the sabertooth escs, they are a little fragile, try some electronizes much more rugged.
                              oh, i have a lifty pushy boring robot, runs 4wd off of 4 GR01 motors and it can lift around 50 kg
