I was just thinking though some options, and was wondering how I could connect multiple receivers to one transmiter, in the past it would be easy, just use a few 40 MHz fm receivers, connected to one transmitter, but due to the change of rules, I can't do that. So I don't know the alternative options. I could butcher to transmitters together, or do some fancier transmitters, have the ability to be binded to multiple receivers? I don't have much experience withe the more expensive ones, so I don't know whether I could. Like what did stinger do after the rule change? Thanks
Radio gear
Re: Radio gear
In answer to the original question, if you have a 2.4GHz radio set (spektrum, Planet 5, Radio Link), you take however many receivers you want and bind them to the same transmitter like you would normally. When you power them up they should both bind. Stinger is set up like this, with a receiver in each wheel.
Re: Radio gear
just a small prob with either transmitter or receiver (spektrum dx5 and a ar6100e receiver)
ive tryed to use the left joystick right/left channel to control my lifter but non of the channels on the receiver seem to be connected to it but the throttle and all the other channels seem to work fine
has anyone else had this problem
