robot not moving?
  • robot not moving?
    my robot has power to it because the reviver light is on so the power is going through the esc's but there is no movement on the motors?
    Re: robot not moving?
    need a bit more info mate
      what would you like?
        what make is the esc ....does it have a built in BEC or are you using a battery to the receiver
          this is the esc
          http://www.ebay.co.uk/itm/2x-Marine-50A ... 3f0df2b70d
          and it dosnt need a seperate battery
            are you using a v trail mixer as well
              yes
                i had fun with this u have to disconnect the bec on both speed controllers a get a separate battery or BEC as the 1s on the speed controller will fight each other and 1 wont give enough power to run everything
                  http://www.youtube.com/watch?v=zdUhLH7BS4E
                  a good vid about it
                    Just disconnecting one bec should be enough.
                      i tried that with my set up and it didn't it could just be the v trail but when i disconnected both and added a separate BEC it worked
                        so ive got to cut the red radio wires coming off the esc and add an external power sorce to the reciver
                          well on the vid is shows you how to pop them out incase you ever need the bec .. and then u just use some insulating tale to rap them up............. it might work if you just disconnect 1 i think it depends on the v trail but i read on another post that your better off with a separate bec cos if the controller gives up u can still use weapons and 1 side of ur bot will still work
                            cool thanks alot!
                              i got a bec off ebay for about £2 or £3
