2 speed 900's or 4 drill motors?
  • 2 speed 900's or 4 drill motors?
    I'm planning a FW smidsy but am unsure as to if I should stick with 4 drill motors at 18v or use 2 speed 900's?
    Trying to make it more like the RW smidy with the lifting scoop but I doubt I'll run it with a disk unless someone can make disks that small, yet would probably be so small that it would be ineffective
    Re: 2 speed 900's or 4 drill motors?
    2 speed 900s or 4 gimsons
      *drill motor type motors
        4 gimsons, i use 'em
          Hats the benefit of those over 2 speed 900's?
            4 gimpsons would do fine and be easiest
              Beauty 2 and iv use 2 x speed 900s
              is all depends how good the weapon is realy
                It's main thing with it being a FW smidsy is it being a good rammer, so I just can't decide which would be beast too use, one motor per wheel but weaker, or 2 motors for 4 wheels but are stronger motors
                  if i was to make a rammer (BORING BOX) ups i would use 4 speed 900s
                    Boring box WITH A LIFTER!
                    It's probably one of the only big EW bots not made FW, trying to make a FW and ant version of it (eventually)
                      Gimsons all the way
                      with a 100mm actuator also a gimson
                      also there wheels a SMIDSY esk, make it small and make it in metal, O and get the dude who owns SMIDSY to measure it so you get the proportions right
                      http://www.gimsonrobotics.co.uk/GR01_pl ... motor.html bargain at £25.90 each
                      http://www.gimsonrobotics.co.uk/GR01_pl ... motor.html you wont look back
                        matt does own smidsy, scary i know :wink:
                          What you need is reliability, if a Gimson messes up simply take it out unscrew the wheel and slap another in
                            Haha, it's scary how I own a big spinny thing, bust turned it into a big rammy thing and will make it into a big lifty thing
                            So the view seems to be 4 gimson's?
                              you won't regret it
