stuck for a design idea
    Re: stuck for a design idea
    Sounds fine. You will also need a shaft and bearings for the bar. I'd recommend a shaft of at least 17mm diameter silver steel or similar.
    http://www.technobotsonline.com/pulleys ... x10mm.html
    These would do for timing belts/pulleys for the bar. Make sure you get a spare belt or two.
    You can go for the box section construction if you want but few feathers go that way. Instead the monocoque is prefered. You've got a number of options but the easiest to make is a plastic based one. Nylon for structural bits and pieces.
      Cheers Gary, forgot about that
      I've got enough for armour, spare esc's, metal for chassis
      So I need some motors, wheels, batteries and the disk set up. Should come under £120 if I shop right. This will probably be a one event spinner just too see how it goes
        even at the worst, it should cost £140 to build the spinner
        if i can sell enough of my crap that i dont need then it should be achievable
          What escs are you using?
          Originally posted by mattsdragons
          So current list is:
          Box frame chassis
          Polycarb armour
          2 drill motors
          Set of wheels
          15a ESC with 30a fuses to run 18v
          18v Nimh pack
          Fan motor
          Stainless steel bar
          Relay/ESC, what ever I can get
          2 pulleys for 1:1 ratio? Not sure yet
          Belt
          Various bolts etc
          All sounding good?
            woops that was supposed to be a pm
            At least I can use the quote thing now
              electroize or what ever their spelt like
                do you use the fuse to make them higher voltage?
                • #23
                  nope, just add a bigger fue in he 15a ones to decrease the chance of it blowing
                  • #24
                    thats cool (and helpful)
