hi iv'e been looking at some second hand 1s on eBay and a lot of them seep to be either mode 1 or 2 and i was wandering if it matter which type i get
transmitter
Re: transmitter
Ive just bought a spektrum dx5e I have a couple of questions if someone could help me.
The reverse servo buttons are below the surface are they supposed to be like that.
It only takes 4x aa bats, is there a battery pack that I can get that would charge via the socket on the spektrum.
What receivers are compatable that gives the fail safe mode?
Thanks
Re: transmitter
yes they are. Stops you accidentally hitting them mid fight/flight
4 rechargeable double As would do the job if it takes regular AAs. Then you just have to get a charger that plugs in and charges at 6v.
Fraid I can't help you on the receiver side, been a while since I've looked at spektrum kit
Re: transmitter
The DX5 normally come with a AR500, these stop outputting a signal in failsafe mode, so as long as your speedos have failsafes built in, you will be fine. I have had issues with all of my AR500s failing though after about 2 years.
Like Gary said, just put normal nicad/nimh AA cells in, i guess you can buy a charger for 6v, dont use a normal TX charger as they're for 8cells.
Re: transmitter
has anyone ever used any of these receivers?
http://www.ebay.co.uk/itm/Orange-6ch-Re ... 27c1a4ad3e
http://www.ebay.co.uk/itm/spektrum-ar61 ... 20c1d3abf5
with the specktrum dx5e?
Re: transmitter
any one used these transmitters before and can suggest which is better
http://www.giantcod.co.uk/giantcod-24gh ... 03852.html
http://www.inwoodmodels.com/product_inf ... b539188730
