TX/RX - Failsafe - Mixing .....How do you do it?.....help
    Re: TX/RX - Failsafe - Mixing .....How do you do it?.....hel
    I've been looking at the rules again (i should do this more often really) and its says that a light must be displayed when the bot is in failsafe. Can I ask how people have done this. There is of course a power light but how do you wire up a led for when the bot is in failsafe?
      Thats a recommendation, I don't bother with that.
        That's been in the rules for ages, but as far as I'm aware it's advisory only. I've certainly never seen it enforced and can't imagine it'd be a simple addition in the same way a power LED is.
          thats what I was thinking seems like alot of work, thanks for clearing that up.
            Any info on removing the half throws from a DX5E?
              You mean on the transmitter mix?
              I believe that a seperate V tail mixer sorts that problem out.
                Yes I do, and just trying to avoid incorporating additional components, would be nice if I could just use the Tx.
                • #23
                  Give up and buy a V tail mixer.
                  • #24
                    Can anyone tell me where I can get a metal bezel thatll hold a 8mm led
                    • #25
                      Does the GWS mixer work with spektrum dsm2 radio gear?
                      • #26
                        you could always make one yourself quite easily, do you have access to the lathe?
                        • #27
                          I dont anymore jonny. I can find plenty of plastic bezels for 8mm leds but no metal ones.
                          I think the mixer would only be of benefit if using q four channel where you can control both driving channels on the one stick.
