Speed 900s
  • Speed 900s
    Are these the proper speed 900s? Or the replicas? Because they look real, but I thought the proper ones were £60 not £40. Thanks
    Re: Speed 900s
    I think you've missed the link out.
      Re: Speed 900s
      If its the ones on eBay, then I'm sure they are replicas of some sort. I'm thinking of running two of them on 30a electronizes but I'm not sure whether it's worth the investment seing as I'm running four 18v drill motors at 24v at the moment
        Re: Speed 900s
        i have considered these yet ive found running 12v drills on 18v gives me a bot that's plenty quick enough
          Re: Speed 900s
          I have that setup, and I agree, any faster and it would start getting really hard to control.
            Re: Speed 900s
            Proper ones are £40. Got mine a few weeks ago from Cornwall models
              Re: Speed 900s
              Woops!!!! Its: http://www.sussex-model-centre.co.uk/sh ... sp?id=5438 and i used drills before, but they don't have the strength/speed/ shape/reliability I require, bruiser used drill motors, and it was ok, but nothing better, I wont to build a faster more competitive robot, which can be fast, so it can easly get round the RL/RR arenas, with out boreing the audience...
                Re: Speed 900s
                On the real Speed 900 what is the schematic for the attachment hole positions? Also in the pictures it looks like thee is a small bit that sticks out the front of the the mouuting frame with the shaft. What is the diameter of that and how far does it stick out from the mounting frame?
                Or does anyone have a good CAD model of it, preferably solidworks... (Yeah long shot I know)
                  Re: Speed 900s
                  A speed 900 has a nose of 22mm, 6 long.
                    Re: Speed 900s
                    Ok, and does anyone know it's touque? Just so I can see if the gear reduction I plan to do is ok
                      Re: Speed 900s
                      A real Speed 900 does 1.1 Nm@12V in stall
                        Re: Speed 900s
                        Ok, and how much force would it take to drive a robot? Would 2.5 kg of force per wheel be anough?
                          Re: Speed 900s
                          Depends on other factors too.
                          biggerwheels have less roll-resistance, to give one of the variables.
                            Re: Speed 900s
                            Roll resistance? What is that? And btw, it's 4 wheel drive
                              Re: Speed 900s
                              Roll Resistance. (Google it please)
                              The reason why cars are getting bigger wheels over time.
                              See the difference between an original mini cooper and the new one. And no, it's not a marketting ploy, but a way to get a little better fuel efficiency without investing big loads of money into more efficient engines.
