Re: pneumatic dies
You can replace the Pinvalve with an On/off valve for a paintball bottle.
One of the pin valve filling pieces you have can be adapted to the Trevor. Otherwise, a fitting replacement nut isn't difficult to make, just takes time.
Actualy, if you fit one of those pinvalve adaptors directly to the Trevor, and use it with the pin valve bottle...
The knob is good enough to fill the place of required isolation valve.
Again, not that difficult, but takes time...
