i know its probably a dim question but what thickness steel would be equivalent to 1mm titanium?
1mm titanium strength equivilent
Re: 1mm titanium strength equivilent
Titanium is considerably tougher than steel.
Having worked in steel, on and off, for most of my working life (35 years) I can tell you that bending or shaping mid grade Ti is a bloody site harder than good mild steel of even twice the thickness.
Skink's flipper blade is 1.5mm Ti and took some effort to bend to shape.
Skink is now over five years old and despite hundereds of fights I have never had to re-shape the blade.
This would not be true if it were steel.
Mike.
currently using 5mm ali chequer plate, very poor grade as it bends when the robot lands on the unsupported corners. Am looking at 1.2mm grade 5 Ti as a replacement. Would the Ti be able to resist the bending if it had a 14-odd kg bot falling on its corner?
Sounds 5mm HDPE would do better at those spots.Originally posted by Danjr1currently using 5mm ali chequer plate, very poor grade as it bends when the robot lands on the unsupported corners. Am looking at 1.2mm grade 5 Ti as a replacement. Would the Ti be able to resist the bending if it had a 14-odd kg bot falling on its corner?
that would be easier, and a lot cheaper! think i might give that a go and see how it gets on at maidstoneOriginally posted by maddox10Sounds 5mm HDPE would do better at those spots.Originally posted by Danjr1currently using 5mm ali chequer plate, very poor grade as it bends when the robot lands on the unsupported corners. Am looking at 1.2mm grade 5 Ti as a replacement. Would the Ti be able to resist the bending if it had a 14-odd kg bot falling on its corner?
