Hi,
I've got a dx6i spectrum transmitter and a sabertooth 2x25 esc, I have put on travel adjusts on the elevation and aile channels as I am using 24v and don't want to fry sabertooth. I set it to use 10% of the power available so I could easily tell if it is working or not, it seemed to limit the movement when I told it to go straight forward or straight to the side (both motors turning at the same time both times) but when I told it to go forward and turn (only one motor turned this time) and it seemed to have double the power. Just wanted to know if this is what should be hapenning or is it using more than 10% of the power? I am not worried about this now but when I set it to use 50% power I don't want it to draw more or it will fry sabertooth .
Thanks,
Max
Thanks,
Max
