switch
  • switch
    can the switch for my robot be a toggle switch?
    Re: switch
    what swich?
      Re: switch
      if you mean the link ...then no
        Re: switch
        the power switch cus u need a link a power light and a switch?
          Re: switch
          the power switch ie the on and off in a robot is the link
            Re: switch
            You don't have to have a switch. Most people just use a link to turn their bots on and off.
            TBH it's just something else to break/turn off your robot.
            If you insist on having one though try using a key switch as this is unlikely to be toggled through impact,
              Re: switch
              You could use toggle switch for power, but the battery live (,+, positive, red, whatever) must go straight to a removal link - basically wire loop with a connectors.
              The reason for it is that the link can be pulled out in the event of an emergency (robot stuck in forward drive, electric shock, axe in leg, whatever), creating a large gap in the power supply circuit .
                Re: switch
                it would be pointless to add another switch to the wiring just something else to forget to turn on, and another
                weakness to any robot
