Just bought some Argos drills and took the drill apart to get the motor, but I wasn't sure exactly what I have to do to lock the 'clutch thing', I have seen the o ring method but havnt seen what you have to do to lock it with nuts/grub screws.
Argos drill motors
 Re: Argos drill motors
 Set screw = grub screwOriginally posted by MaxJust bought some Argos drills and took the drill apart to get the motor, but I wasn't sure exactly what I have to do to lock the 'clutch thing', I have seen the o ring method but havnt seen what you have to do to lock it with nuts/grub screws.
 http://www.robowars.org/guides/guides-d ... cking.html
 Hijacking the thread. I've seen some roboteers taping the fan holes in the drill motors to not let anything in which is a good idea.
 But I'm just wondering if you guys have seen any erffect on the performance of the motor or anything as it surely will get hotter?
 I have screwed in 4 grub screw and now they just spin in their holes without going further in, yet I can still turn the motor with the screwdriver when screwing in the reverse screw. Does this mean that the clutch is not locked properly?
