hi,
i am still in the process of building my first robot (trax) but am starteing to plan for my next robot, a drum spinner. i am going to order 20mm thick hdpe plastic off direct plastics for the walls which i will screw onto an aluminium base plate. to power the drum i will use speed 900s and argos drill motors for the wheels. Just a few questions:
-where is the best place to buy speed 900s?
-can i use the robochalenge 'battle switch' to control the drum, and does it feture reversing and does it work with dc?
-if not what should i use?
-i don't want to have a bar going all the way across te drum, what do other people do?
-i considered sandwiching angle grinder disks (4 or 5) imbetwween hdpe rod(90cm diameter), would this be effective?
- and finally could i use one of these batteries(link bellow) for the speed 900s and one for the drive motors? would i be better to buy new?
viewtopic.php?f=166&t=3989
No replies saying don't do this yet, finish your first then move from there, spinner are dangerous and you should build an axe bot etc.
Thanks
Max
Thanks
Max
