building a drum spinner
    Re: building a drum spinner
    yeah, we can battle our upgraded robots
      ill have a 1vs1 battle with you after one of the shows if we can?
        That'll be good to see my robot thrash yours!
          may i join in in the fight i think i will use my normal tactics; trundle around for about 20 seconds, get link knocked out, spend rest of fight upsidedown in the corner
            you have 4wd, but i have claws
            and harry, you could join in if you want? i can have a 4kg box to play with when ive thrashed L.A.S.E.R.
              Sure Harry, I'll get my friend to join in.
              PS I'll bring the 2mm HDPE to Worthing
                Mine has a lifter beat that!
                and it will push you around.
                • #23
                  no more 4kg for me, its about 6.5kg atm without weapon!
                  • #24
                    ILL STILL HAVE YA
                    • #25
                      Which ever of you whether it be Matt or Harry buys Daiske you can run that as part of a cluster bot with Harrys 6.5kg machine, would still be will within the limit .
                      • #26
                        I have a fealing that mine is overweight . Send it to weight watchers!
                        • #27
                          *goes to ring team mate*
                          • #28
                            .........fat git!
                            mine is the opposite, in theory it will be underweight
                            • #29
                              yeah if any body wants a partner for a cluster bot, drop me a line :wink:
                              • #30
                                The plan with Daiske was to add 4WD and an electric lifter and even then I doubt it will be much over 7kg.
