Re: featherweight flipper systems
With FP , a low powered system still delivers a few 100kg
Surface of piston in cm²*pressure of CO2- 55bar= force in Kg.
Meaning a 40mm piston delivers 690 kg. - relative losses , give or take 600kg .
The 12oz bottle we use in Hannibalito III weights in at a hefty 1.1kg full.
A Burkert 5404 (reasonably affordable solenoid valve that can do the job) weights 660 grams.
Ram (40mm bore*80mm stroke), collector and buffertank, with PRV and dumpvalve, can be done in 2 kg
4.5 kg to 5 kg is a reasonable weight for a full weaponsystem.
