PMEUMATICS
  • Re: PMEUMATICS
    I'd suggest this from ebay ask for a 12v coil and the plug.
    http://cgi.ebay.co.uk/Pneumatic-Directi ... 1e5eaa1679
    • Re: PMEUMATICS
      So u mean to buy the valve as well as the plug and coil
      • Re: PMEUMATICS
        i just got one of these there good! and it comes with all bits and pieces just say what voltage you want quick delivery too!!
        • Re: PMEUMATICS
          Yes
          • Re: PMEUMATICS
            Just wondering what is the weight of a 150 psi/10.2 bars is in kg
            • Re: PMEUMATICS
              The construction of your sentence makes no sense ...try again.
              I guess that your missing a word e.g. regulator?
              • Re: PMEUMATICS
                OK
                What is the average weight (in kg) of a 150 psi/10 bars????
                • Re: PMEUMATICS
                  OK
                  of a what? 150 psi is a pressure ...it's like saying what is the average weight in kg's of a blue / green
                  • Re: PMEUMATICS
                    You seem stumped...
                    You've supplied a pressure rating without saying what the pressure rating applies to.
                    Anything pneumatic can be given a pressure rating
                    A valve @ 150 psi / 10 bar ( This pressure is the industry norm )
                    A Fire extinguisher might be rated @ 1000 psi / 68 bar etc...
                    For information on the weight / mass of the item you must be a little more specific.
                    E.G. The weight / mass of a 1/4 5 port valve.
                    The weight / mass of a 100mm bore 200mm stroke cylinder.
                    Even then it's a very open ended question.
                    Pic of a selection of regulators ranging from 2.5kg's down to 200g ...the smallest ones are not suitable for you they only output ( unless modified ) a low pressure
                    [attachment=0:2esa8y9s]P1010016c.jpg[/attachment:2esa8y9s]
                    • Re: PMEUMATICS
                      any idea where to get one ? apart from trev cos hes nt replied
                      • Re: PMEUMATICS
                        RIGHT:
                        Whatis the average weight of a 150psi/10 (and a bit) bars pneumatic system of a featherweight?
                        Theo
                        • Re: PMEUMATICS
                          i tried aswell but no repliy
                          Theo
                          • Re: PMEUMATICS
                            No
                            I've always made do with what I have kicking around.
                            What is the average weight of a 150psi/10 (and a bit) bars pneumatic system of a featherweight?
                            Good grief!.....Um
                            0.6kg co2 bottle full weight ...1kg ish
                            Regulator 0.5 - 0.75 kg
                            Valve ( complete ) + fittings + tube 0.5 kg ish
                            Pneumatic cylinder 0.5 - 1.5 kg's depends very much on construction and size.
                            relief valves plus bits and bobs 0.5 kg...
                            Plus a buffer tank if your going to use one
                            GUESSTIMATES ONLY
                            To the optimist, the glass is half full. To the pessimist, the glass is half empty....To the Robot builder there is just too much glass.
                            • Re: PMEUMATICS
                              can anyone suggest a suitable buffer tank please?
                              • Re: PMEUMATICS
                                I hear that a fire co2 bottle will do
                                Theo
