batterys and pnumatics
  • batterys and pnumatics
    hi
    i have 2 14v drill motor(and gear box)
    what batterys should i use? (a.k.a how many volts and mah (not to much money(and i have a good charger for most battery types)
    and where should i get the batterys?
    and what is a good place to get stuff for a lowish psi pneumatic flipper???
    theo
    Re: batterys and pnumatics
    Lead acid are good if you have more money NiMh are better you can also use LiPo's.You'll want a 14v and around 3000mah battery, technobots sell lead acid and car dealers sell them to.If you want NiMh the robo market place do design-a-pack or go to overlander batteries as they are good.
      i think i will use the batterys i have now for my 45mph rc car ....
      intill i have some more money
      there only 8.4v but 4500mah which is good
        i think i am going to get a co2 tank from...
        http://www.amazon.co.uk/approved-20oz-C ... 149&sr=1-5
        and most of the other stuff apart from a valve (reg, a valve to let psi out, and stuff like that from...
        http://www.technobotsonline.com/
        and a 5/2 valve from ebay
        but where can i get a double acting cylinder
        THEO
          jonno can get the co2 tanks most people use then you know its correct etc
          i dont know alot about flippers etc but you can get the rams from ebay
            Ok but if it is more I am going to go with amazon (or I will nick a fire exthingy
            what is his username ( porbs seen him before but bad with names)
              whats jonno username?
              and whats the best type of welder tig, mig or what??? (lots of weird names)
              theo
                His username is roamingrobots.
                Might be best to email though - email can be found on http://roamingrobots.co.uk/?pages=contact
                  thanks
                  and what is the best thing to weld aluminum tig, mig or what (weird names)
                  Theo
                    hate to say it but if you don't know the difference between tig and mig then I wouldn't start trying to weld aluminium. Get a simple arc welder for around 50 quid and start on steel. Much easier to pick up the basics of welding.
                      i know what mig is and tig (mig is gas)
                      and my dad is buying the welder
                      and i was just woundering what is the best type of welder to buy
                      theo
                        Ironically enough with that comment you have shown that you don't know the difference. Both Tig and Mig processes use gas. Each differs with how the filler material is added to the weld.
                        With regards to the best welder Tig is the prefered method
                        http://www.mig-welding.co.uk/aluminium-welding.htm
                        That page shows quite nicely the difference in quality of welds with both techniques. Problem with Tig is that the machines can be more expensive than mig.
                          ok
                          where is a good place to get a mig welder
                          theo
                            is this battery good!!!
                            http://store.modelpower.co.uk/3s-2200ma ... 1330-p.asp
                            and where can u get a cheap mig welder
                            Theo
                              I'd highly recommend staying away from lipo batteries until you are more familiar with bots. Nimh far more suitable.
                              Check out ebay for a welder
