Using gold motors
The plan is Mod 0.8 gears from HPC gears at 3.8:1 ratio (I was quite surprised at the lack of range available from RS infact). The Mod 1 gears are just a tiny bit too big for my chassis which is a shame as they wouldve actually been far cheaper.
See if you can get hold of a couple of old 24v Golds and use their front plates instead of the ones fitted on the 12v ones.
Whats the advantage, it looks pretty similar in construction to the 24v version, although as with the bearing is the face mounting plate different? Im actually on the way to running the 12v at 18v, Im just planning to use 3 4AH 6v SLAs in series, just a nice and simple, cheap solution.
LOL! Does make a big difference.
