Re: From The Ground Up (Advice Thread)
for welding screening the focus is not allowing uv light through so as long as whatever you put there stops uv getting through then it should be fine. remember you need decent air circulation though as gasses given off from welding can be toxic. as for robot pictures i tend to just look through photobucket and rr database
