From The Ground Up (Advice Thread)
  • Re: From The Ground Up (Advice Thread)
    alot of foam
      Sorry, I made that sound like I needed the volume filling, what I mean is, I have 7kg left and I have 100 by 300cm of armour that needs fitting and I don't know what would be viable materials at that weight, nor how I could reduce the current weight or size. I'm really at a stand still!
      Edit: Solved the issue, I realised that I could reduce the weight, I'm ruddy tired and not thinking straight, sorry about that.
      Are Trollied, Wasted, or Hammered available as Robot names, I haven't heard of them before but I thought I'd just check?
        3m * 1m of armour? you could cover a heavyweight with that much
        Going by your dimensions and design on page 5 you should only need about 4000 sq cm of armour max not 30000
        You're currently looking at 2-3 mm of hdpe or 1-2 mm of polycarbonate/cfrp/gfrp and probably nearer the lower end of those ranges so not the best armour.
          I didn't notice either that I'd calculated 30000 cm sq (so tired)
          After my new designs (Page 5 is quite outdated) I have 3800 cm sq to cover with armour, and according to http://www.jindalstainless.com/toolkit/ ... lator.html 15mm HDPE at high end HDPE standard at directplastics - 96 g/cm^3 (checked the density on their data sheets) equates to 5.5kg rounded? One of us has done wrong calculation, and chances are it's me.
            Correct mass, missing a decimal point in the density though (0.96g/cm^3)
            It's time to go to bed when you start designing robots with materials 6 times more dense than the sun as armour
              Good advice if ever I've heard it.
              And I'm sigging that if you don't mind!
                It's probably more than 6 times if you include the corona that goes stupidly far into spaaaaaaaaaaaaaaaaaaaaaaaccee...
                  Just noticed my battery packs exceed the perimeters for sabretooth controllers, 25v with 42 batteries? Way over. I'm assuming I can modify the packs I've bought so that I use less cells, this depends on how much current I need, would 3300mAh be enough for a 4wd 18v pusher?
                  I think I could modify it and change them to two packs of 12v 3300mAh, but that would leave me with 20 cells, which I noticed Gary said in another thread burnt out sabretooth controllers he had bought. 10.8v batteries? That keeps me in the perimeter? Aaaaah
                  Edit: Or simpler, 25v with 21 cells, that doesn't exceed the perimeters by much and drops half the cells? Thoughts are desperately needed!
                  Thanks again
                    Hm, does anybody know any good countersunk allen head screw vendors? Me typing it into google only shows up naff results.
                    Thanks!
                      I got some recently from this eBay seller: http://www.ebay.co.uk/itm/M6-X-30-COUNT ... 1047wt_905
                      He has different sizes and quantities too.
                        10quid for 100?? get yourself down to a fastners place, think i paid about £2 last time for similar
                          Found a site that sold m6*40 for 6 quid or something, only bought 50 though.
                          Couldn't find anything called 'fasteners place'? eBay seemed to expensive though.
                          Thanks anyway guys!
                            where you based?
                              Lewes in East sussex, same as the Terror Turtle team. I'm up in Whitby, Yorkshire at the moment though. I don't think there are many east sussex roboteers.
                                Active teams i can think of are Turtle, Big Brother, Barbaric Response, not sure about feather teams.
                                Just search for Fasteners in google or yell.com, most will have a trade counter.
