Overvolting drill motors
  • Overvolting drill motors
    Not sure if I am going to use 9.6, 12 or 18 volt drill motors yet, but what would be the optimum voltage for these motors, I have heard that you should only overvolt by 50% is this correct. I will be running 100mm wheels
    Re: Overvolting drill motors
    In reality there isn't much point to overvolting drill motors as they are generally too quick as they are, however if you wish to overvolt a good rule of thumb to follow with all motors is to, as you said, run them at 150% of their rated voltage. This is by no means a guarantee that your motors won't burn out but gives you somewhere to start from.
      Has anybody got any thoughts on the best voltage drill to use ie 9.6 12 or 18 volt (before overvolting)
        id go for 12 volt drills then you could either go on a 12volt batt or 2x 7.2v in series to make 14.4v
          yeh, I want to know about drill motors as well, like how much faster do they go when you overvolt them if you use 50% more volts than your spost to does it go 50% faster
            yep thats right only over volt by max of 50 % to ensure the longevity of the motors (obviously over volting a motor can kill it)
              thanks
                overvolting drill motors wont do much, they are generally fast enough as they are.
                  depends what your after
                    even with 100mm blue wheels 500 RPM drill motors only go 5.9 MPH and I think thats to slow , were as 750 RPM Drill motors with 100mm wheels goes 8.85 MPH which is fast enough
                      You'd be surprised at how fast drill motors go on their regular voltage. I generally don't bother overvolting them and just run them regular or if i do then run them with 50% or whatever on the sticks as they are too fast otherwise. Remember that 6mph is roughly 3 meters per second and the robot will get there almost instantly. That's a fair bit in an arena measuring 10m by 5m max or thereabouts
                        ok I will just go for 6 mph then if you think its fast enough
                          build the bot with the drills on regular voltage and try controlling it then you can decide if you wanna uprate or not
                            ok I will do that
