Overview
  • #31
    Overview
    Three questions ...Yes ( but not enough in general to worry about )... Yes and Yes.
    http://www.google.co.uk/search?hl=en&q=cordless+2+speed+drill+rpm&btnG=Sea rch&meta=cr%3DcountryUK%7CcountryGBhttp://www.google.co.uk/search?hl=en...btnG=Search&me ta=cr%3DcountryUK%7CcountryGB
    • #32
      Overview
      Danke Schonne .
      Will need that. Merci.
      Grazie,
      Alex
      P.S Corrections on Danke schonn? I think I miss -spelt it.
      EDIT: Will this be O.K on the torque front?
      http://www.argos.co.uk/static/Produc...t%3EDRILLS.htm
      (Message edited by aero_storm on October 10, 200
      • #33
        Overview
        That is a corded drill and so works off 240AC not (as you are allowed in the rules) up to 36V DC.
        A simple rule. If you plug the drill into the wall, it isnt useful to you. If it has a battery that needs recharging every so often and is in the voltage range of 9.6V to 36V it is useful to you.
        O and stay away from hammer drills. Stopping the hammer motion is a bigger hastle than its worth.
        (Message edited by typhoon_driver on October 10, 200
        • #34
          Overview
          Ok. What about these. I know Im just throwing links around but this is a forum.
          Thanks for the advice about the plug although the problem probably would have become clear once I had bought it
          http://www.argos.co.uk/static/Product/partNumber/7106127/Trail/searchtext%3EDRILLS.htmhttp://www.argos.co.uk/static/Produc...rchtext%3EDRIL LS.htm
          http://www.argos.co.uk/static/Product/partNumber/7111686/Trail/searchtext%3EDRILLS.htmhttp://www.argos.co.uk/static/Produc...rchtext%3EDRIL LS.htm
          http://www.argos.co.uk/static/Product/partNumber/7110340/Trail/searchtext%3EDRILLS.htmhttp://www.argos.co.uk/static/Produc...rchtext%3EDRIL LS.htm
          Thanks,
          Alex R
          • #35
            Overview
            Ill throw a link back at you ...one that I gave before ...http://www.4qd.co.uk/faq/roadspd.htmlhttp://www.4qd.co.uk/faq/roadspd.html
            Put in the cordless drill RPM ...1,200
            You will be screwing a wheel on in place of the drill chuck so ...Gear Ratio = 1
            Use a wheel dia of 100mm
            Output = You tell me Alex R
            Id really like you to try and use the calculators.
            The above rpm and wheel size is fairly common if your using cordless drills as drive motors.
            Woody
            • #36
              Overview
              The reason I was asking for more drill links is because the speed that a 1100 rpm drill gives me with 4 inch wheels is about 13 mph. So I have, in fact, used the calculator, and done everything you have told me to do on the calculator. This is a forum. Im not as experienced as you, but if I was I wouldnt be here.
              Alex
              • #37
                Overview
                quote:
                Im not as experienced as you, but if I was I wouldnt be here. Thats not a great attitude, just leaching of the knowledge of others because you havent yet. So the second you know all you need youre out of here?
                • #38
                  Overview
                  I knew that would be thrown back in my face.
                  No, thats not what I meant. I do appreciate the help Im getting. I was a bit irked due to the fact that despite trying my best I just wasnt good enough. But, hey, Im not experienced, I have built no robots, so Ill take what comes.
                  Alex
                  P.S Back to the topic now?
                  P.P.S Sorry :blush:
                  (Message edited by aero_storm on October 11, 200
                  • #39
                    Overview
                    Alex R ...I happily make allowances for newbies ...young or old.
                    Whilst I could have given you the specs for everything ...I believe its a good idea to at least make you do some homework on the subject.
                    So homework done.
                    I think for the price range your looking at ( cheap ) perhaps 4 off 9.6v drills run @ 12v with 100mm wheels giving you approx 8 mph.
                    Getting the higher 1000 plus rpm will probably require you to double or treble your £ spend.
                    • #40
                      Overview
                      Ok, thanks. My calcs say that if I overvolt a 750rpm motor with 7cm wheels, I get 13mph. This is what I will go for. Then Ill just see what happens.
                      Alex
                      • #41
                        Overview
                        Your overvolting by how much?
                        50% is really the limit...giving you 1100 rpm ish instead of 750 rpm .
                        10cm wheels @ this rpm gets you to 13 mph
                        • #42
                          Overview
                          Yup 50%. with 7cm wheels you get 9 mph.
                          *Sigh*.
                          I want to use 7cm wheels but its too slow. What a bore:sad:.
                          Oh well, my grandpa is coming down today and I will talk about it with him.
                          thanks,
                          Alex
                          • #43
                            Overview
                            Why work with drill motors and gearboxs?
                            Other options are open.
                            • #44
                              Overview
                              O.K. Im going to splurge on 2 1000 rpm and do you think it would be possible to chain connect it to the front wheels? Ill overvolt it by 50% and with 7cm wheels we should be off at 16mph with a lot of pushing power. Yee haw.
                              Please correct me if I am horrifically wrong.
                              Alex
                              • #45
                                Overview
                                The aggravation and cost of chain + sprockets to drive the rear pair of wheels should be considered.
