Ive finished wiring up BOOM! and the motor controller seems to be cutting out regulary. I played around with it a bit and found that with exponential control on and a slow movement of the stick it works fine. Any sudden movements of the stick cause it to cut out.
I have been told this is very much like what happened with Swannys machine and it could be a case of needing toput some caps across the motors.
The motors are RS-550s (says on side of them) and I was wondering firstly what size of capacitors and then connection details?
Andy
Andy
