Just done some testing with Seraphim and found it works well without any steel armour/Counterbalance plate on the front this saves 2.3Kg!! and now makes the robot about 12 Kg weight.
I may put a bit back on so I can fit a longer sword, or an axe. What do you think it needs?
Who can stand against The Great Seraphim?
I was wondering if anyone was willing to try to push Seraphim in the pit, or flip it OOTA, there is a fiver for the first to do this, anyone brave enough to try!!
Since my exams finish next week that should leave plenty of time to get Whirlwind up and running so I can have a go at getting Seraphim OOTA
Anyway here are the stats for Whirlwind
Weight ~13.6kg
Length ~40cm
Width ~50cm
Height ~ 20cm
Weapon- FP Flipper with a 60mm bore, 80mm Stroke ram fired by a burket with a 9oz painball bottle for the buffer tank.
Drive: 2x 50:1 MFA motors running at 24v with 80mm diameter wheels
Speedo: Scorpion XL
Batteries: 3700mAh 24v Ni-Mh
Radio- DX6i with AR500 rx
Armour- 3mm Aluminium frame with 10mm Nylon/HDPE base with 5mm Welded HDPE armour
Notes: Should be ready for RIAT
Also here is my brothers replacement for Shockwave
Weight ~13.6kg
Weapon- FP flipper with a 45mm bore, 50mm stroke ram, fired by a burket with a buffer.
Drive: 2x 18v Drills running at 24v with 75mm wheels
Speedo: Scorpion XL
Radio: DX5e with BR6000 rx
Armour 5mm HDPE on 3mm Aluminium frame
Notes: Should be ready for Guildford
May be subject to change - design is done, and a fair number of the parts have been acquired already though.
THE DESTROYING ANGEL:
Weight ~13.6kg
Length ~40cm
Width ~30cm
Height ~6cm
Weapon: ~4kg overhead horizontal spinning bar, powered by dual brushless outrunners through a spiral bevel gearbox. Torque limiter on the weapon shaft to remove some of the shock loading from the gears and motors.
Drive: Dual 550 motors through Banebots gearboxes.
ESC: Sabertooth
Radio: Spektrum dx5e
Batteries: 12x A123 cells (4 for drive, 8 for the weapon)
Armour: 3mm 6-4 Ti top and bottom, 10mm UHMWPE sides with hardox front wedge and 3.2mm hardox side plates. If I end up having the weight, I'll put a couple of mm of Ti on the rear.
