My hammer bot.
    My hammer bot.
    O.K thanks very much.
    Rob
      My hammer bot.
      Im doing what Mario suggests, only MOD 1.5 ram as my seals are 16mm not 20mm, again it is a 50*100 ram.
        My hammer bot.
        16mm, strange, my 40mm ram has a rod of 16mm. I would have expected a 20mm on the 50mm bore version. But its perfectly possible that a 20 or 25mm rod is used on the next size of rams above 50mm, the 63mm bore.
        But then, I dont have any problems adapting that.
          My hammer bot.
          i built an axe robot out of ply wood as a template to make a stronger one at a later date and here it is
          http://uk.youtube.com/watch?v=qWF-iHJ8u2Aaxe
            My hammer bot.
            robot- looks good
            mario - eds not using a normal shape piston i dont think, but why would u want to adapt it?
              My hammer bot.
              I ment that I dont have any problems adapting the rack to the ram or visa versa. Just that I have to buy the rack to fit the piston or visa versa
                My hammer bot.
                What gearing are you using between the motor and the axe? How heavy will the axe be when its finished?
