Hello all. After the question about the bar or disc I decided to go off and build a hammer bot
. I have already started. I have a lot of questions for people. The first one. I plan to make it a full pressure cylindar on co2. Is this a good idea for a FW. Also I plan to use the rack and cog system in which the cylindar is attached to a rack and that is lined up with the cog which has the axe welded to it. My measurements say that will offer 1.32 times the velocity and it will get up to speed faster. Again: is this a good idea? Thirdly I plan for the hammer to only be drawn back about 100 degrees from the ground. Is this a good idea or shall I pull it all the way back. Last question. Hammer or sharp thingy.
Thanks all
Rob
Thanks all
Rob
