Just been testing Cyberon with my new scorpion xl,and I think I have found a batch fault.
The fault I have is the same as Whirlpool....which is the controller works fine for 2 minutes then the little signal strength light starts to flicker slow at first, ending as a fast flicker.During this time the reciever is very intermittent making the robot judder. The circuit board itself is still cold on the bottom but very slightly warm on top. Whirlpool discovered that if they put a little fan blowing onto the top circuit board, the problem seemed to get better. I have just done a test with my wifes hairdryer and found that, if I blow cold air on top of the circuit board the flashing light slows down and radio reception works. If I switch to heat setting, within a second the controller freezes. The problem I have is that my wife wont let me keep the hairdryer ! So I will have to fit a small fan if my robot is to stand a chance on Saturday. Do you think this is a batch problem or that all Scorpions should be fitted with fans ?!
